Новини - модели - Архив 2019г.
Регистриран: 02 апр 2007, 09:49
Мнение от simo » 31 дек 2018, 18:46
Продължаваме новините от производителите на модели в нова тема.
Регистриран: 02 яну 2012, 19:25
Мнение от Клуб Стендов Моделизъм България » 01 яну 2019, 06:00
News
Real Model Ltd. high quality resin kits, conversion sets and accessories
1. pf 2019 - 2018-12-31 18:14:39
Мнение от Клуб Стендов Моделизъм България » 02 яну 2019, 00:00
The Modelling News
Latest in news and reviews and kit builds from the scale modelling world
1. Revell39s new releases named for 2019 - some things old,some thing39s new... - 2019-01-01 14:48:00
Revell has joined the fray in releasing a list of some of their new kits for 2019. Several scales, more genres and even more types of vehicles, ships and aircraft are listed. See for yourself if the releases in our preview are interesting to you or not...
Read on... »
2. Kitthawk39s 32nd scale Dassault Mirage 2000 D/N is rapidly approaching... - 2019-01-01 09:12:00
Kittyhawk release boxart of their Mirage 2000 D/N just today - this two-seater variant designed for Nuclear strike is slated for release mid-2019 - so not long to go now, folks! See more about the kit in our preview...
Read on... »
Мнение от Клуб Стендов Моделизъм България » 02 яну 2019, 06:00
RailRoad Modeling RSS Feed
This is the official RSS Feed for RailRoad Modeling.
1. Atlas: 2-Rail Caboose Trucks - 2019-01-01 18:04:56
TWO-RAIL FRICTION BEARING CABOOSE TRUCKS are O scale models from ATLAS MODEL RAILROAD.
Мнение от Клуб Стендов Моделизъм България » 02 яну 2019, 12:04
KFS-miniatures
Portal modelarski
1. Garfy8217s Get a Grip Pro 8211 uchwyt do malowania figurek - 2019-01-02 08:08:57
Garfy8217s Get a Grip ProPainting Handle Miniature Model HolderGarfy8217s Get a Grips
Uchwyty do malowania figurek z PK-Pro są dość dobrze znane i cieszą się zapewne zasłużoną estymą. Niemniej jednak ich dostępność, i jednak cen,a zachęcają do poszukiwań alternatyw. Dodatkowo, z mojego punktu widzenia ich wadą jest brak kompatybilności z typowymi korkami z butelek wina. Te ostatnie uważam bowiem za całkiem praktyczne ze względu na rozmiar, a poza tym mam ich nieco nazbierane 8211 dzielnie i z trudem 8211 bo przecież wina nie wyleję do zlewu. Z niemałym zadowoleniem odkryłem zatem istnienie uchwytu, który zaprojektowany jest tak, by współpracować ze wspomnianymi korkami. Zamówienie przyszło dość szybko, w niewielkim płaskim pudełku 8211 co mnie nieco zdziwiło, ale okazało się, że główny uchwyt po prostu trzeba zmontować z dwóch połówek spakowanych osobno. Zawartość zestawu prezentuje się zatem następująco
Jak widać, producent pomyślał również o niepijących oraz mieszkańcach krajów nordyckich, dla których zakup wina celem pozyskania korka może przekraczać wartość omawianego tu zestawu. Wszystkie elementy 8211 poza korkiem, rzecz jasna 8211 są dziełem drukarki 3D. Mamy zatem główny korpus uchwytu..
..działający na zasadzie klipsa, w którym po rozwarciu można zamocować korek
..korek z figurką. Bo jak wspominałem, uważam, że jest on dość uniwersalny i praktyczny przy malowaniu małych ludzików 8211 choćby dlatego, że nie ogranicza dostępu do powierzchni od dołu 8211 co w wielu sytuacjach jest jednak istotne. Niemniej jednak korek nie jest przesadnie stabilny, a gdy zamocujemy na nim figurkę metalową, czyli jednak ciężka, to stabilny przestaje być zupełnie. No chyba, że wstawi się go właśnie w taki choćby uchwyt. Pomijam kwestie ergonomii, bo o tych więcej coś będę wiedział jak poużywam tego diwajsu, choć wstępne przymiarki są zupełnie obiecujące.
Możliwości uchwytu nie sprowadzają się jednak wyłącznie do dzierżenia korka. Jest on bowiem przystosowany również do mocowania w nim figurek na typowych okrągłych podstawkach 8211 jak zapewnia producent w rozmiarach 25mm, 32mm, 40mm and 50mm. Wszystko to dzięki widocznym na pierwszej fotce pomarańczowym pierścieniom
Citadelowskich podstawek we wspomnianych rozmiarach nie mam, ale jak widać 8211 generalnie patent się sprawdza. Choć w przypadku podstawek z Kingdom Dead, które są cieńsze od standardowych potrzeba jakiejś podkładki, by całość się nie gibała
Drugim niezwykle ważnym ficzerem, czy nawet pierwszym w zasadzie, jest specjalne ramie stanowiące podparcie dla palców podczas precyzyjnych prac. Ono również składa się z dwóch wydrukowanych elementów, które trzeba ze sobą złożyć
..a następnie wcisnąć na uchwyt. Przyznaję, obawiam się o ten właśnie element, bo przy montażu potrzeba użyć nieco siły 8211 mam nadzieje, że tworzywo, z którego został zrobiony wytrzyma wielokrotne zakładanie i zdejmowanie
Zaprojektowane jest to tak, że ową podporę można dość swobodnie obracań niemal w koło uchwytu
..no i całkiem wygodnie kolorować laleczki. Czy tam je rzeźbić
KFS
The post Garfy8217s Get a Grip Pro 8211 uchwyt do malowania figurek appeared first on KFS-miniatures.
2. 1/35 Panzerspähwagen TKS (p) 8211 IBG Models - 2019-01-01 13:04:52
1/35 Panzerspähwagen TKS (p)IBG Models 8211 35047
Pojawienie się tej edycji było oczywiste od samego początku. I to nie tylko dlatego, że jak wiadomo niemcy sprzedają się prawie tak dobrze co cycki, ale w ramkach od samego początku były dwa detale typowe dla TKSów zhańbionych teutońskimi krucyfiksami. Chodzi mianowicie o reflektory 8211 bo to one właśnie służą do germanizacji panlechickiej stali
..przy czym już w pierwszej recenzji zestawów TKS wskazywałem, że mamy tu do czynienia z haniebną zdradą 8211 reflektory te są odlane w jednym kawałku 8211 a nie jako sferyczny korpus, z doklejaną szybką klosza. Czyli mamy detal co to niby jest, ale i tak trzeba robić w zasadzie od podstaw
Jeśli chodzi o plastikowo 8211 blaszaną zawartość, to nie licząc nieobecnych tutaj figurek, omawiany zestaw jest w sumie bliźniaczy do edycji TKS z CKM Hotchkiss wz.25. Jest to zatem wersja modelu z ogniwkowymi gasienicami
Nowa jest więc jedynie kalkomania 8211 niezbyt zresztą obfita, bo to głownie balkenkrojce, ale nawet jedna nazwa własna pojazdu
I z tymi kalkomaniami mamy możliwość zmalowania TKSa w jednej z czterech opcji 8211 trzeba przyznać, że są to malowania całkiem różnorodne
..przy czym wciąż nie są to najbardziej smakowite, a raczej najbardziej znane malowania tekaesów w niemieckiej służbie. Czyżby IBG planowało jeszcze jeden zestaw hańby?
KFS
The post 1/35 Panzerspähwagen TKS (p) 8211 IBG Models appeared first on KFS-miniatures.
Scale Model News
1. GERRY ANDERSON39S SPACE 1999 NUCLEAR WASTE DISPOSAL AREA DIORAMA KIT - 2019-01-02 08:00:00
GERRY ANDERSON MOONBASE ALPHA FANS have the chance to make a realistic diorama with the MPC 1:48 scale Nuclear Waste Disposal Area 2 kit.
Read more »
Мнение от Клуб Стендов Моделизъм България » 03 яну 2019, 00:00
RetrokiT
Welcome to our store!
1. New RetroTracks kits announced! - 2019-01-02 08:35:38
As promised we have now added four new future 8216hardware8217 references to our 1/35 and 1/72 RetroTracks catalogue.  The T13 Type 3, never released in this scale ever before is to meet the numerous demands from our customers for this particular vehicle, which after all, was the most common AFV in service in Belgium in May 19408230  The JPK90 kit is more of a commission from a retired Belgian army JPK90 driver, but we know from our experience with the 1/72 kit of this AFV we released a few years ago, that this will be another best-seller too.  To this we can add a further two new 1/35 figures and in time we will also reveal the nature of some 1/35 accessory packs that will complement our other 1/35 releases.  We are set to release the three new 1/72 RetroTracks kits later this month (Berliet GPE4, Lorraine 28-1 Command Car and Citroën P104), and we thus plan to release at least another two kits during 2019, including a brand new Belgian T13 Type 1 / Type 2 kit that benefits from all the research that went into its larger 1/35 brother released in 2018, and an Autocar U-8144-T that should be followed in time by a semi-trailer and a pontoon.
Amateurs of our Chibi RetroTracks range do not despair, we are also thinking of you and the next set of releases is due in for late February 2019..!
Updates about of other ranges will follow shortly!
In the meantime, Happy New Year, Trackheads of the World!
The post New RetroTracks kits announced! appeared first on RetrokiT.
The Modelling News
1. Construction Review: 1/35th scale Waffenträger auf E-100 from Amusing Hobby - 2019-01-02 00:00:00
Straight from the fictional world of "What-if" and World of tanks comes the new kit in 35th scale from Amusing Hobby - the mighty Waffenträger auf E-100. The best review is a build review so we got to building this kit in a Step-by-Step to show you just what is in the kit and how it goes together...Read on... »
Мнение от Клуб Стендов Моделизъм България » 03 яну 2019, 06:00
1. NOCH: Travellers - 2019-01-02 05:43:21
NOCH offers many figure sets in several scale. This set is TRAVELERS, and N scale set of nine figures.
Мнение от Клуб Стендов Моделизъм България » 04 яну 2019, 12:04
KFS-miniatures
Portal modelarski
1. 1/35 3Ro Italian Truck 8211 Troop Carrier 8211 IBG Models - 2019-01-03 10:59:12
1/35 3Ro Italian Truck 8211 Troop CarrierIBG Models 8211 35055
Lancia 3RO to po Scammelu kolejny dość ikoniczny pojazd, który przez lata w miniaturze dostępny był wyłącznie jako zestaw żywiczny, a IBG postanowiło ten stan zmienić. Temat może wydawać się niszowy, ale po pierwsze w naszych czasach coś takiego jak niszowy model nie istnieje, a po drugie mając opracowane podstawowe komponenty 3RO można puścić na rynek wiele wersji tego pojazdu. Co akurat idealnie wpisuje się w politykę IBG. Zresztą już na dzieńdobry dostajemy dwa typy 8211 pojazd uzbrojony w haubicę oraz będąca przedmiotem tego omówienia ciężarówkę do transportu żołnierzy. Ciężarówkę całkiem niemałą, a więc i pudełko z modelem jest duże, a do tego pełne plastiku
Mamy zatem całkiem sporo ramek, przy czym jak pokazuje niniejszy diagram 8211 wiele z nich występuje w większej ilości sztuk
A zatem:
Do tego mamy koła, a w zasadzie opony, zrobione w technologii znanej z Rosomaka czy wspomnianego we wstępie Scammella (w pozostałych ciężarówkach, z projektem o nieco starszych korzeniach koła robione są bardziej klasycznie)
Do tego mamy dwie ramki z elementami przeźroczystymi 8211 całkiem udanym jak na IBG, bo wciąż jeszcze nie perfekcyjnym oszkleniem, oraz kloszami reflektorów
Do tego jest również całkiem okazała blaszka fototrawiona
..dość przyzwoita
..choć zawarte w nich jakieś cięgna czy linki to akurat słabo nadają się do wykorzystania 8211 syndrom edkowych instalacji elektrycznych 8211 nie dość że jednak płaskie, to jeszcze delikatne 8211 to lepiej zrobić z dodatków własnych
..i tak 8211 instrukcja taka jak zwykle w modelach IBG. No nie jest to najmocniejsza strona zestawu. Jak zwykle zresztą
Przy czym jak widać, jest to całkiem zaawansowany model 8211 i nawet jeśli elementy konstrukcyjne są dobrze spasowane, to jednak nie będzie to zestaw na początek przygody z modelarstwem. Choćby ze względu na sporą ilość elementów. A jak owe elementy wyglądają z bliska? Zacznijmy od kół. Opony dzięki wielodzielnej formie mają ładnie odtworzony bieżnik i nieco detali, z napisami włącznie. Oczywiście nie jest to poziom, jaki oferują żywice, ale już prosto z pudła powinno wyglądać to naprawdę ładnie. Choć nie bez obróbki, bo jednak tu i ówdzie widać pozostałości łączenia poszczególnych kawałków matrycy
Skoro o fakturach mowa, to na szczęscie deski części ładunkowej pozbawione są imitacji słojów -dobrze, bo to bardziej niż rzadko wygląda dobrze odtworzone we wtrysku, a współmodelarze mogą łatwo wedle życzenia zrobić je samodzielnie
Podobnie ławki
Stelaż paki jest osobnym, kompletnym elementem
Skoro o stelażach mowa, to mamy tu także ramy pod plandekę (bo samej plandeki już nie). Cienkie i delikatne. No i właśnie 8211 to co jest ich zaleta jest zarazem wadą, bo takie filigranowe listwy nie będą łatwe w obróbce, a za to łatwe do połamania. A jak by tego było mało, to poprzeczne listwy już w ramce są nieco zwichrowane
Całkiem nieźle prezentuje się szoferka, choć dostrzec tu można pewien brak konsekwencji. Na przykład tylna ściana o ile od zewnątrz ma wiele detali, to od środka jest całkowicie gładka. Ale siedzisko i oparcie są nawet niebrzydkie
..tymczasem znacznie mniej eksponowany dach ma od środka imitacje desek 8211 a od zewnątrz 8211 imitację pofalowanej szpaty (choć nie wiem, czy te ugięcia nie są przesadzone 8211 zakłądam jednak na tym etapie, że projektant miał na to kwity)
Drzwi kabiny są osobnymi elementami, można je zatem zamontować w dowolnej pozycji
Podobną swobodę oferuje konstrukcja maski, a przy tym nie wykluczone, że nawet jedną połowę można by zostawić w modelu ruchomą (tylko po co?). Skoro przy masce jesteśmy, to jednak imitacje żaluzji nie są tu najbardziej udane. To się prosi o0 blaszany zamiennik
Nie wykluczam jednak, że niejednego otwarcie maski będzie kusić, bo silnik i okolice są nawet dość szczegółowe 8211 choć przyznaję, że nie konfrontowałem tego jeszcze z materiałem zdjęciowym
Ogólnie rzecz ujmując układ napędowy i rama podwozia są dość szczegółowe i ładne. Pewnie znowu będzie marudzone, że koła się nie skręcają, ale mechanizm tu jest na tyle rozbudowany, że moim zdaniem to nawet lepiej. A jak komuś naprawdę będzie zależało na skręcie, to powinien sobie sam poradzić z modyfikacjami
Tyle o plastiku. Zostały nam zatem malowania. Tak wyjątkowo IBG daje dość skromny wybór, bo całe dwa warianty
Do tego mamy więc niemały arkusik kalkomanii. Prezentuje on jednak typowy przerost formy nad treścią, bo zawarte w nim oznaczenia spokojnie mogły by się zmieścić na połowę mniejszym kartoniku. Ale nie to jest tutaj problemem. Uwagę zwraca bowiem brak nalepek na cyferblaty wskaźników deski rozdzielczej 8211 niekompetencja czy #zdrada wciąż?!?
KFS
The post 1/35 3Ro Italian Truck 8211 Troop Carrier 8211 IBG Models appeared first on KFS-miniatures.
Мнение от Клуб Стендов Моделизъм България » 05 яну 2019, 00:00
The Modelling News
1. Bronco39s new T-34-85 but in 32nd scale?? - 2019-01-04 04:01:00
It seems that there has either been a typo or Bronco Models has launched the first in a new series of 1/32nd armour kits - We think the latter - as the new kit of a rather famous  T-34-85 from the Chinese army in the Korean conflict is Kit No# 32001! See what we know about this latest kit from Bronco in our preview...Read on... »
Мнение от Клуб Стендов Моделизъм България » 05 яну 2019, 06:00
GB Modelli
Artisan production (handmade) resin kit in 1/72 scale - Produzione artigianale (fatti a mano) di kit in resina in scala 1/72
1. Featured Products - 2019-01-04 10:54:00
Kit 72071 - Aerofono Galileo O.G..34 with 3 figures included
2. Kit 72070 - German Stug L6/40 da 47mm SPG Version "G" - 2019-01-04 10:53:00
Bibliografia:Italian Armour in German service 1943-1945 di Nicola PignatoGli autoveicoli tattici e logistici del Regio Esercito italiano fino al 1943” di Nicola Pignato e Filippo Cappellano, Stato Maggiore dell’Esercito – Ufficio Storico, Roma 2005.Le artiglierie del Regio Esercito nella Seconda Guerra Mondiale, Filippo Cappellano, Storia Militare, 1998.
Le forze armate della RSI 1943-45, Carlo Cucut, GMT, 2005.
http://www.italie1935-45.com/regio-esercito/materiels/item/302-semovente-l-40-da-47-32
Мнение от Клуб Стендов Моделизъм България » 05 яну 2019, 12:04
KFS-miniatures
Portal modelarski
1. 1/48 Soviet Tank Crew (WW2) 8211 Reskit - 2019-01-04 12:54:18
1/48 Soviet Tank Crew (WW2)Reskit 8211 RSF48-0004
Moje poprzednie spotkanie z małymi ludzikami z ResKit było umiarkowanie udane. Tym jednak razem obrazek na pudełku zapowiadał jednak lepsze wrażenia
Pudełku typowym dla tego producenta. Wnętrze tez typowe 8211 czyli elementy żywiczne są upchane pomiędzy dwiema warstwami gąbki. Może to i zabezpiecza przed uszkodzeniem, ale mimo wszystko przydałaby się dodatkowo torebka strunowa, żeby zminimalizować ryzyko zgubienia elementów. Bo ludziki są rozczłonkowane
Na pierwszy rzut oka wydają się dość duże, ale po porównaniu z niedużą przecież laleczka z Tamiya wychodzi na to, że są minimalnie tylko wyższe. No i bardziej masywne, ale tu z kolei może to być kwestia zimowych, niespecjalnie obcisłych uniformów
I muszę przyznać, że są to nawet całkiem udane ludziki. Może daleko im do choćby tych ze Scale75, ale na pewno nie straszą jak poprzednio omawiane figurki z ResKit.
KFS
The post 1/48 Soviet Tank Crew (WW2) 8211 Reskit appeared first on KFS-miniatures.
2. 1/48 US TANKERS 8211 WarFront 8211 Scale75 - 2019-01-04 10:14:27
1/48 US TANKERSWarFront RangeScale75 8211 SW48-005
To nie jest tak, że jestem wrogiem rzeźbienia cyfrowego i druku wzorów figurek. Po prostu nazbyt często rzeźba jest pokraczna, a druk budżetowy, wiec nie najlepszej jakości. Tymczasem projekty cyfrowe mają to do siebie, że (w przypadku figurek) dość łatwo jest je przeskalowywać. Zabieg ten stosuje Scale75 w swojej linii żołnierzyków WarFront. Dodajmy, że stosuje z powodzeniem. Jakiś czas temu opisywałem zresztą zestaw figurek w skali 1/72, a potem jedną z nich, ale już jako trzypiątke. Omawiany tutaj komplet ludzików w 1/48 jest również dostępny w pozostałych dwóch wielkościach. A jak się prezentuje? Opakowanie jest standardowe, czyli blister, po którym luzem pałętają się żywiczne elementy figurek
..elementy, bo tutaj każda z obydwu postaci ma osobno jedno ramię
Jak już wspominałem w poprzednich recenzjach żołnierzyków ze Scale75 rzeźbę maja nad wyraz udaną. Nie budzi zastrzeżeń również jakość wydruku wzorów. Co prawda na upartego da się tu i ówdzie dotrzeć jakieś ślady warstw wydruku, ale w miejscach zupełnie nieszkodliwych. Same odlewy również są na zupełnie niezłym poziomie, choć jak to w żywicach, nie uniknięto delikatnych szwów po cięciu gumowej formy
..i na koniec jeszcze porównanie gabarytu 8211 w odniesieniu do tamiyowego ludka (a Tamiya robi dość małe figurki) 8211 postury mają podobne
KFS
The post 1/48 US TANKERS 8211 WarFront 8211 Scale75 appeared first on KFS-miniatures.
Мнение от Клуб Стендов Моделизъм България » 06 яну 2019, 00:00
The Modelling News
1. MiniArt39s 2019 catalogue full of current and some new items the new year you might want to see... - 2019-01-05 12:16:00
Miniart has published their newest Catalogue of items for 2019 - This time they have released the whole catalogue at once so you might see a few new things you may very much like - check it out and see in our preview...
Read on... »
Мнение от Клуб Стендов Моделизъм България » 06 яну 2019, 06:00
1. Cavalex: PGA Truck Renders - 2019-01-05 21:55:25
Cavalhex has posted CAD renders of their upcoming N scale PGA trucks
Заключена
Върни се в “Новости от производителите на модели / Manufacturers' news”
